banshee blew up rebuild questions
Old Oct 20, 2008 | 07:59 PM
beastlywarrior228's Avatar
Default banshee blew up rebuild questions
since my banshee blew up i was wondering what would be the best bore for motocross
Old Oct 20, 2008 | 11:48 PM
Raptor450's Avatar
I would just go the next size up from what you have to save room for more rebuilds later. Get a nice set of high performance pistons and you'll be good to go.
Old Oct 21, 2008 | 08:03 PM
stageIVbanshee's Avatar
yeah go next size up. only get forged pistons because cast crumble after a year of hard running. vertex and namura are cast. wieseco and i think vetoes are and stock are forged.
Old Oct 21, 2008 | 10:43 PM
what happend is the piston ring came off and put gouges in the head
Old Oct 22, 2008 | 12:13 PM
knear06's Avatar
try having someone sand blast the head and if it doesn't look to bad it will work.
Old Oct 22, 2008 | 12:49 PM
91Warrior357's Avatar
might be able to just get it honed
Old Oct 22, 2008 | 08:33 PM
knear06's Avatar
ok wait is it in the head or is it in the cylinder walls?
Old Oct 23, 2008 | 04:46 PM
head the cylinder walls are fine but i was wanting to get it bored cause i want more power
Old Oct 23, 2008 | 10:36 PM
knear06's Avatar
well if it's the heads then you can get it sandblasted and it should work i done that and it did but you can go with a cool head which are kinda cheap around 250
Old Oct 23, 2008 | 10:37 PM
knear06's Avatar
and if you bore the cylinders it won't give you as much power as you think it will.
