350x honda atc motor into a 84 200s
Old Oct 22, 2008 | 12:12 AM
moppymcjones's Avatar
Default 350x honda atc motor into a 84 200s
I was interested in putting a 350x motor into my 200s just because. I was wondering what other people thought and if it is too hard or if anyone has done it before.
Old Oct 22, 2008 | 11:32 AM
maggiesboy's Avatar
"One Wheel Short"
Moppy,
If you have unlimited access to a machine shop and a tig welder anything can be done. The main question for you is this. Is it worth my time and effort to make this thing function properly, and function safely?
for the amount of time you put in to modifying the frame, it will be alot cheaper to just find a 350X chassis. Then you have suspension, and disk brakes.
If you are planning on turning it into something like a puller, go for it. A rider, no way.
Just my .02 and don't want to cut down a fellow triker, and his ideas.
Bill
Old Oct 22, 2008 | 06:13 PM
ok, thanks for the heads up. i was wondering if it was possible without major modification. That's definitely not worth it, I'll just finish fixing the 200s back up. I was already working on it in my garage so i figured maybe i could make it faster. My friend bent the axle, hand brake and foot peg, cracked the body smashed the guard case for the chain into the chain- then claimed he didn't break anything as i was following behind him well he was doing 35mph over a log - then top of a rock - hitting a tree in the air - flipping the three wheeler on it's side into the ground.... his words were after it all happened was that he just flipped over at 5mph... The greatest part was when the three wheeler kept running.
Old Oct 28, 2008 | 01:18 AM
Basstromboon's Avatar
if you don't use it would you like to sell the 350x motor?
Jul 22, 2015 05:00 AM
95wolv
Jul 17, 2015 08:13 PM
ghost civic
Jul 15, 2015 10:48 PM
timster911
Jul 13, 2015 01:57 PM
