banshee vs. r450
Old Oct 22, 2008 | 12:10 PM
knear06's Avatar
Default banshee vs. r450
ok i need some help i have a 99 shee with fmf exaust bored .60 with the stock carbs and no boost bottle. well a friend of mine has a suzuki r450 stock and he is just kicking my ***!! i set my shocks to where the front end won't come up as much he's killen me off the line everytime..but on top speed i have him beat. any mid priced parts would be helpful and also i'm purchasing a cool head here soon also. so any help would be nice!!!
Old Oct 22, 2008 | 12:46 PM
91Warrior357's Avatar
take off in 2nd gear, your bikes a 6 speed, also make sure you tires hook up. the 450 has way more bottom then you and has better suspension, so it prolly launches better than you.
Old Oct 22, 2008 | 02:48 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
Something don't sound right. Assuming your jetted properly and you talking about a drag race, that thing should not beat you off the line. My bro used to lean forward and rev to powerband and pop the clutch. It wouldn't stand up on him (granted he is about 245lbs) and would often spin the tires on asphalt. It was the deciding factor in our drags. If I could get him off the line or get as good of a launch I'd get him in the mid range otherwise I couldn't catch him. If your on dirt it'll be tough cause the 'shee won't get traction.
Old Oct 22, 2008 | 06:48 PM
knear06's Avatar
well we've have never tried it in second gear but i was racing a friend of mine on his yfz450 and his had 1 tooth down on the front sprocket and he got me off the line by a little bit but this zuzuki is kicken my *** off the line but what are some common parts for a shee i don't want to add a boost bottle given some ploblems i have heard about them but any other ideas would be helpful???
Old Oct 23, 2008 | 11:35 AM
Endo's Avatar
Drop a few teeth in the back and start in second. If you guys are matched in traction, you need to make sure your on the pipe when you launch and then you shouldn't be any issues.
Old Oct 23, 2008 | 11:46 AM
Koopa's Avatar
Boost bottle waste of money in my opinion if your looking for upgrades go for a set of vforce 3 reeds.
Old Oct 23, 2008 | 12:05 PM
redmoon85's Avatar
PLUS, if you're running 20's in the rear or bigger, the Suzuki is running 18's, unless they were changed. That has a big difference on not only top speed, but also off the line starts. If he is running 18's, and you 20's, and no other gearing, there could be your problem.
Like you said, you get him on top speed but he gets you off the line. Tire size and gearing have that effect.
Old Oct 23, 2008 | 12:34 PM
Koopa's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: redmoon85
Like you said, you get him on top speed but he gets you off the line. Tire size and gearing have that effect.</end quote></div>
Good point. In my case my bro was running 18" on the 'shee. Not much around here could take him on launch.
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
