2007 50&90 predator to slow
Old Oct 22, 2008 | 03:57 PM
mxgrandpa's Avatar
Default 2007 50&90 predator to slow
I really need help to find restrictors on the 50&90 predators to gain a few more miles per hour. pictures would be helpful.
thanks
Old Oct 22, 2008 | 05:40 PM
colt2245p's Avatar
on the 2 stroke units you had to remove the wire tab from the box up under the front plastic.its right in the front under the nose piece and on the left side. its a small rectangular box with 2 screws on the side. loosen them up and ratote the tab upwards and tighten the screws back up....on the 4 stroke models there is no restrictor other than the throttle stop on the handlebars that you adjust
Old Oct 22, 2008 | 05:42 PM
Should be small plate on cdi located above air box secured with 2 screws, loosen screws,remove plate and will have full power. Also should be screw and locknut at throttle,can adjust for more/less travel.
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
ReconBayou
Sep 23, 2015 02:41 PM
Sep 23, 2015 06:23 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
