help with 86 bayou
Old Oct 22, 2008 | 08:53 PM
atvcrazzy's Avatar
Default help with 86 bayou
the atv has sat for a geed while so I cleaned the carb, changed oil and filter and all of that. I get it started and it is sucking air at the isulator part #10673 (the pat with the o-ring in it) where it meets the head, it may also be sucking air between that piece and the carb mount part #16065. what should I do? Do I replace them, put blue glue of it or what, lol. I would greatly appreciate any help
Old Oct 22, 2008 | 09:31 PM
Hayashi's Avatar
So, air is leaking in between those parts?
Why is air leaking in anyway, broken or worn-out?
You may try non-pemanent glue like RTV sealant.
Does the engine start at all?
Old Oct 23, 2008 | 12:17 AM
atvcrazzy's Avatar
yes starts but dies when you rev it, the parts look fine. you can spray carb cleaner on these parts and the idle speeds up
Old Oct 23, 2008 | 12:02 PM
Hayashi's Avatar
Well, time to try sealing up the joint area.
Old Oct 23, 2008 | 05:01 PM
atvcrazzy's Avatar
how do I seal it, can't use blue glue cause gas will dissolve it, so what should I do?
Old Oct 23, 2008 | 05:13 PM
Hayashi's Avatar
There RTV that are resistant to fuel/gasoline. Look around.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
wendal
Sep 15, 2015 01:50 PM
rcappie4
Sep 9, 2015 07:04 PM
