more serious then i think
Old Oct 23, 2008 | 06:56 AM
671warrior's Avatar
Default more serious then i think
my 1995 warrior had a bit of smoke and flame came from the carb and then a loud bang then shout down by itself. i was just thinking it was from a dirty carb. i didnt try to start it after that happened. but took out the carb today and metal chips were all over the inside of the carb. the biggest one was about as big as an index finger. i know im in deep trouble. any help besides an engine change would be very helpful.. if so what type of motor would a bolt in type. even though i know it would make it easier. thanks.............
Old Oct 23, 2008 | 09:18 AM
Raptor450's Avatar
Just rebuild the engine you already have.
Old Oct 23, 2008 | 11:19 PM
671warrior's Avatar
thanks that sound good.... for now
Old Oct 24, 2008 | 01:10 AM
Raptor450's Avatar
Nothing to it... you probably shattered the piston or fried it. Just get a new piston & rings, gasket kit, and have the cylinder bored at a machine shop. They even have kits you can buy where you don't even need a machine shop - you buy a whole new cylinder. If you can do the work yourself you can have it done for less than $300. Then if you get it running try to figure out why it blew up. Warriors don't just fry the engine for no reason. You may have dropped a valve if you revved it too high.
Old Oct 24, 2008 | 11:21 AM
671warrior's Avatar
yeah i think that was it. i was reving to race my brother in law with his banshee and it just blew a flame with a smoke ball. thanks though. and dam cause i knew i could have taken that win.........thanks again.
Old Oct 24, 2008 | 11:29 AM
redmoon85's Avatar
Sounds like you may have dropped a valve. Have you ever had them adjusted? Check the carb, even minimal damage will ruin it. Good luck.
Old Oct 24, 2008 | 05:30 PM
Raptor450's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 671warrior
yeah i think that was it. i was reving to race my brother in law with his banshee and it just blew a flame with a smoke ball. thanks though. and dam cause i knew i could have taken that win.........thanks again.</end quote></div>
Yeah I think you would have beat that Banshee with your Warrior!
fredrikrosen
Oct 29, 2016 07:56 PM
black_thunder
Sep 20, 2015 10:21 PM
Canamaniac!
Sep 4, 2015 06:44 PM
Reactant
Jul 27, 2015 07:45 PM
