2001 grizzly 600 air/mixture screw?
Old Oct 24, 2008 | 04:38 PM
azsth's Avatar
Default 2001 grizzly 600 air/mixture screw?
Thanks for all the help from last week.
I had several issues causing the idle problems. One..the previous owner had some strange air filter installed that did not fit.
Second it had air leaks between the carb and the intake.
Plus the carb was a bit dirty and the o-rings were worn.
So now most of the issues are done but...it would seem to run a bit rich....not terribly so just a bit.
Now there was a post earlier on this question and I saved the exploded view of the carb.
Which screw adjust the air fuel mixture if I need to lean it out...and is accessible (it should be) from the outside of the carb. Is it on the underside? I just can't tell and I do not want to adjust the wrong one.
Again I appreciate the help and I am 90% there.
I did put a K&N air filter on....although no other changes were done...like no cutting of the air box.
scott
Pgbama11
Jan 16, 2016 08:19 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
chewy78
Sep 8, 2015 10:37 AM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
