96 magnum 425 2x4
Old Oct 25, 2008 | 04:00 PM
asvs84's Avatar
Default 96 magnum 425 2x4
I have a 96 magnum 2x4 and I need to change the center sprocket. How would I go about starting this?
Old Oct 25, 2008 | 04:25 PM
xplorerman's Avatar
take off the caliper then thear is a circlip on the shaft holding on the roter remove the clip & rotor after that thear might be a circlip in frount of the sprocket if so remove it then pull the sprocket off reverse to install
Old Oct 25, 2008 | 04:30 PM
asvs84's Avatar
thanks for the help
Old Oct 25, 2008 | 10:57 PM
xplorerman's Avatar
not a problem hope it helped you
Gwolf228
Feb 18, 2017 01:36 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Sep 9, 2015 06:57 AM
Dan Newberry
Aug 30, 2015 09:42 AM
