cant get the bike to go in diagnostic mode
Old Oct 28, 2008 | 02:45 PM
badazz400's Avatar
Default cant get the bike to go in diagnostic mode
hey guys,
im trying to get the screen to throw a code at me for my bike just cuts off when it wants.
am i missing something? i put the bike in park. turn the key off, then on and off three times within 5 sec. and still i recieve no "wait" on the screen
is there a trick to this????
thanks
ross
Old Oct 28, 2008 | 02:53 PM
jml9700's Avatar
At least on my quad, the check engine light needs to be on to get a flash code. And when you turn the key on the first time, it counts as number one etc... I pretty much have to turn the key 3 times before the pod display lights up completely. good luck man!
Old Oct 28, 2008 | 03:28 PM
badazz400's Avatar
yea thats what i figured. i called my dealer and he knew exactly what my problem was (tbap harness) he said for 125$ it can be fixed. i guess ill have it done by them..
Old Oct 28, 2008 | 05:48 PM
awa04's Avatar
You can buy a t-bap harness and saver yourself some money. Very simple. Good Luck
Old Oct 28, 2008 | 10:02 PM
mdj104's Avatar
on mine (08 Sportsman)it has to be in nutral,turn key off,wait 10 sec. press rev overide and turn key on..
Old Oct 29, 2008 | 09:22 AM
speedy63's Avatar
my 06 500efi was doing that same thing, but would start right back up until the last time. Everything was dead. Took it to the dealer as it is still under the extended warranty and they found the Power Distrubution Module was bad. Good thing they paid to fix it as it would have cost me around 500 for them to do it. I've never been able to get mine into diagnostic mode either.
Old Oct 29, 2008 | 01:10 PM
jml9700's Avatar
The dealer first thought it was the t-bap harness, then the mechanic told me to try and wiggle the wires on the throttle position harness first, and that's what it was. The orange wire (if I remember correctly) goes from the tps to the t-bap. I was getting a code 45 (Barometric Pressure/Manifold Air Pressure Sensor Low). Sure enough it was the harness on the throttle body and not the harness on the air box. When I messed with the wires, the check engine light would go on and off. I was told the problem was Polaris made the harness too short and the wires would vibrate loose or break. The harness for the t-bap(air box) was about $28, and the tps harness(throttle body) was around $36. It's an easy fix no matter what harness your need to replace. The diagnostic mode while in park and turning the key 3 times is the EFI diagnostic mode, to get flash codes when the check engine light is on. The neutral / reverse override diagnostic mode just gives you general info; battery voltage level, AWD Diagnostic Screen, Gear Circuit Diagnostic Screen, & Programmable service interval. Have a good one!
Old Mar 15, 2010 | 09:13 PM
snowguy's Avatar
I just bought an 06 500 efi and also can't get it to go into diagnostic mode. I checked all the harnesses mentioned and wiggled wires but none of that worked, does anyone have any other ideas?
Old Mar 16, 2010 | 07:29 AM
JCDEYO25's Avatar
For you guys having trouble getting into Diagnostic Mode try this for retrieving blink codes...Make sure the key is off and the atv is in park...Turn the key on and off 3 times within 5 seconds and leave the key on on the 3rd turn...Look at your pod and you'll see the word "wait" appear...If there are any codes stored they will appear on the screen...The word "end" will appear wafter all the codes have been displayed...Hope this helps...
John
Old Mar 16, 2010 | 10:26 PM
snowguy's Avatar
I followed those instructions to the T and nothing comes up on my display. Likewise I jiggled wires and nothing changed. Any suggestions before I take it to the dealer?
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Customer Service #1
May 15, 2020 08:46 AM
lancemll88
Sep 6, 2015 03:03 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
