650 can-am Start in gear Mod!
Old Oct 29, 2008 | 11:18 AM
cobby's Avatar
Default 650 can-am Start in gear Mod!
Has anybody figured out a way to bypass this safety feature? I would like to be able to start in any gear without pulling the brake?
Old Oct 30, 2008 | 11:16 PM
DuneMe's Avatar
There is a little yellow wire down below the countershaft sprocket. I think you just need to ground it (check to see if that does it.)
Your green light on your dash will always be on so, you may want to disconnect it so it doesn't burn-out, etc.
Old Oct 31, 2008 | 10:53 AM
cobby's Avatar
What and where is the countershaft sprocket?????????
Old Oct 31, 2008 | 02:00 PM
jusrlax's Avatar
I believe Dune Me is referring to the front sprocket. Find the drive chain, there is only one visible chain on the outside of the bike, so if you see a chain, it must be the right one. Unless, of course, you use a chain to lock up your bike, in which case ignore that one. Then, follow the drive chain forward towards the front of the bike. You will see a round price of metal with teeth that the drive chain mates to. That is the front sprocket. Somewhere below that and below the oil filter cover, you will find a tiny wire, which attaches to the motor with a tiny ring connector and nut. That is the neutral wire. All of this is assuming you are referring to a DS 650.
<div class="FTQUOTE"><begin quote>Originally posted by: cobby
What and where is the countershaft sprocket?????????</end quote></div>
Old Oct 31, 2008 | 02:34 PM
cobby's Avatar
OH OH
This is a 650 Outty not a ds. It has a drive shaft and thats why this is not making sense
Old Nov 5, 2008 | 10:52 AM
BBR650's Avatar
Is always changing bikes.
it will start in gear, pull the brake.
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Jun 8, 2015 11:05 PM
Jun 2, 2015 02:49 AM
1000gade
May 27, 2015 12:37 PM
