02 700 sportsman loosing coolant in crankcase
Old Oct 30, 2008 | 02:48 PM
asharrock's Avatar
Default 02 700 sportsman loosing coolant in crankcase
I have a 2002 Polaris Sportsman 700 efi. I replaced the water pump seal and I am still loosing anitfreeze into the crank case even while the atv is not running. Any suggestions on what I should try next??
Old Oct 30, 2008 | 05:12 PM
HeftyLefty's Avatar
Do you have water in the oil?. The oil will be milk white if you do. white oil means cracked jug due to overheating, or blown crankcase gasket; due to same. What about exhaust smoke, is it white?. White smoke means blown head gasket, water in combustion chamber.
COFatboy
May 2, 2020 12:06 AM
SDR-II
Sep 29, 2015 01:06 AM
scram5050
Aug 19, 2015 02:19 AM
QuadCity
Aug 13, 2015 12:58 PM
Coryco
Jul 6, 2015 07:30 PM
