stumped
Old Nov 2, 2008 | 01:57 AM
yzballa08's Avatar
Default stumped
starter buttonwont work,headlights work fine ,connections are good,replaced starter relay switch....how can i test the button or fix it
Old Nov 2, 2008 | 01:49 PM
cherokee99's Avatar
Default stumped
did you check your fuses?
Old Nov 2, 2008 | 01:58 PM
snorulz's Avatar
Default stumped
is your neutral light coming on?
Old Nov 2, 2008 | 07:08 PM
yzballa08's Avatar
Default stumped
fuses are fine and yes the light comes on
Old Nov 2, 2008 | 07:22 PM
JeffinTD's Avatar
Default stumped
What kind of machine is it on?
Anyway, it would probably be easiest to test with a volt/ohm meter...
Old Nov 3, 2008 | 12:00 AM
yzballa08's Avatar
Default stumped
04 400ex how can i go about doing that
Old Nov 3, 2008 | 03:53 AM
JeffinTD's Avatar
Default stumped
You could see if you have voltage to the switch, and you could see if you have voltage coming out of the switch when you hit start...
ReconBayou
Oct 31, 2022 05:37 PM
donintennessee
Jan 8, 2021 12:40 PM
Bob E.
Oct 1, 2019 09:08 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Hw00d
Sep 10, 2015 08:53 AM
