trans
Old Nov 2, 2008 | 04:38 PM
lynnedon's Avatar
Default trans
being new to atving, i need to know on a 650 rincon 2005 if the tranny oil and engine oil is the same or is there somewhere to fill trans. we are having a problem with heat light come on and trans wants to slip.
Old Nov 2, 2008 | 07:11 PM
JeffinTD's Avatar
Default trans
The engine and transmission use the same oil. Most places 10-30 or 10-40 would be good, SG or higher, and JASO MA.
Because it is a dry sump, to get an accurate oil reading the machine needs to idle for 5 minutes (10 if it's cold), then sit for a couple of minutes. You probably already know, but don't screw in the dipstick when you check, and you want the oil level at or even a shade above the top mark.
You might also want to make sure the radiator and the oil cooler are clean and free of debris. Sometimes it is helpful to remove the side shroud, so you can get in there to back flush with a hose.
Anyway, welcome to the forum.
Old Nov 2, 2008 | 07:15 PM
lynnedon's Avatar
Default trans
thanks for reply.we sure hope this works.
Old Nov 2, 2008 | 07:20 PM
JeffinTD's Avatar
Default trans
Low oil will cause transmission slipping, so I'd bet that's it.
Also, if the weather is cold, the thing will need to warm up for a bit before it will shift properly.
Old Nov 2, 2008 | 10:32 PM
lynnedon's Avatar
Default trans
filled itwith oil and it has sooooo much power now! thanks for all your help
Old Nov 3, 2008 | 03:52 AM
JeffinTD's Avatar
Default trans
Glad to be useful. Have fun (carefully) with the ATV.
Old Nov 3, 2008 | 09:32 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default trans
The Rincon trans runs hot, and it can toast petroleum oil. I recommend a high quality ester based synthetic oil, like Maxima Estra.
http://www.maximausa.com/produ...e/maxum4synthextra.asp
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
HondaR24
Jul 23, 2015 11:22 AM
Kdgncop
Jun 17, 2015 09:37 PM
foots22
Oct 5, 2000 01:01 AM
