Brute Force Rear Axle
Old Nov 2, 2008 | 12:17 PM
RedBF750's Avatar
Default Brute Force Rear Axle
I have a Brute Force 750 and I needed to replace the left rear axle. I am trying to get the hub off of the shaft but I can't seem to get the nut to budge. Any ideas?
Old Nov 4, 2008 | 12:06 PM
Hayashi's Avatar
Leave the hub and A-arm all attached together and just remove the complete hub & a-arm assembly together from the frame. Once you've done that, pull the hub & a-arm assy staright outward and they should slip off from the axle. If you think the nut you were talking about has to be removed, use a heat gun to heat up and try it.
Hayashi's Avatar
Double clicked.
Old Nov 4, 2008 | 02:43 PM
RedBF750's Avatar
Thanks for the help. After trying to get it off for a while I just ended up cutting the nut with a dremel. This thing would just not budge!
Jenn1
Sep 8, 2015 09:16 AM
snowolson
Aug 31, 2015 03:51 PM
Dammar
Aug 26, 2015 07:12 PM
DeFox500
Aug 14, 2015 05:59 PM
Rollin23
Aug 13, 2015 01:12 PM
