warrior not running
Old Nov 2, 2008 | 11:55 PM
Andrew's Avatar
Default warrior not running
i just rebuilt the carb and got a new coil and im getting goog spark and its getting fuel flow to the cylinder but will not fire up just flood it self out any help will be great
Old Nov 3, 2008 | 04:23 PM
ikeyrider's Avatar
My friend has an old ts250 2 stroke dirt bike and his flooded and would only run for a second or two, what he did was buy a few spark plugs and try until he got it running, i think his first plug was foul. Im not 100% sure but it might be worth a try.
Old Nov 4, 2008 | 11:44 AM
91Warrior357's Avatar
install a new plug and try starting with your fuel turned off and see if it starts if it does then it is deff flooding
Old Nov 5, 2008 | 12:24 AM
Andrew's Avatar
i try it but i just adjusted the valves to .008 for the intake and .018 for the exhaust and it wants to fire up but wont any help will be great
Old Nov 5, 2008 | 12:36 AM
Andrew's Avatar
could it be the cdi? I just dont want to take it a shop but it gots good spark i just dont know any more?
Old Nov 5, 2008 | 01:48 AM
warriorslayers's Avatar
try not turning the fuel on, and drain the bowl on the carb, take off your filter from air box and get some good spraying starter fluid, give it a small spray at first and see if it will fire up, if so then it could just be the carb...
Thats what I always do when everyting seems to be in oder but won't start... make sure that your air to fuel screw is set right,and that your intake boot isn't leeking.... Hope that will help get back to us
Old Nov 5, 2008 | 09:43 AM
Andrew's Avatar
no i set it to 1.5-2 tunrs out but could it maybe the timein?
Old Nov 5, 2008 | 09:51 AM
Ya it's possible, did you try the starter fluid Idea
Old Nov 5, 2008 | 10:03 AM
Andrew's Avatar
yea but it dont work but I hear that you cant adjust it
Old Nov 5, 2008 | 11:13 AM
ikeyrider's Avatar
You need 3 things to run: compression, spark, correct fuel/air mixture. If you have all 3 of these and ur timing is right, it will run. So we know you have good spark, and probably good compression, (which you should test). Now, presuming your timing isnt out of alignment it leaves just one culprit. Your fule/air mix could be the cause. Maybe jetted wrong or such. Post back after you see how much compression it has.
