Banshee Wires
Old Nov 6, 2008 | 03:43 AM
Bigrhys's Avatar
Default Banshee Wires
Hi Folks,
My friend has a standard 2002 Banshee, that was running poorly, he notices that the two wire from the top of the carburettor were damaged, does anybody know what the function of these is.
Thanks
Ivan
Old Nov 6, 2008 | 10:06 PM
stageIVbanshee's Avatar
the wires are from the
T throttle
O over
R ride
S system
the TORS is a common problem with the banshees and the blasters. you can disable them to eliminate this problem. that is what i am having trouble with right now with a friends blaster.
Old Nov 7, 2008 | 06:07 AM
Bigrhys's Avatar
Hi StageIVbanshee,
thanks for the response, can you tell me how you disable these wire, is it just a matter of cutting them, as he feels that when he connected them in the incorrect sequence(black to white and vice versa) the bike seemed to run better, but he can't be sure.
I also carried out a compression test which gave a reading of 7 bar, I believe this to be poor, so I stripped the engine and removed the piston.
The barrels seem fine, both measure 64mm but the piston seem to have a lot of wear at the top, both again are around 63.5mm,
I am currently in the process of ordering replacement std pistons.
Thanks again
Ivan
Old Nov 7, 2008 | 04:52 PM
91Warrior357's Avatar
you can buy TORS eliminator kits for about $60 from Vito's and it will include everything to take tors off and will make life alot easier with your carbs, alot of wear on the top of the piston on 1 side might be from one carb running leaner then the other which is deff not good, id try to get your carbs syncronized so it wont mess up your new pistons and also cause loss in performance as well, you can sync carbs yourself using a carb sync tool like a mercury gage, best way for an example is to look it up on YouTube, just type in carb sync banshee
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
