Hot Cams
Old Nov 10, 2008 | 02:35 AM
Gagt518's Avatar
Default Hot Cams
Im interested in buying the Stage 2 hotcam for my 400EX. My mechanic said that i would also have to pick up a different timing chain tensioner if i used a aftermarket cam. My question is where could these be bought?
Old Nov 10, 2008 | 10:07 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
Default Hot Cams
I have never heard that you have to use a different timing chain tensioner. They make replacements if yours breaks but, they are stock specs.
Old Nov 10, 2008 | 02:28 PM
toondritetothabak's Avatar
Default Hot Cams
I replaced one once on that same bike. The new hot cam didnt have a decompressor on it, like the stocker did, and it was very hard starting, and hard on the starter motor.
Old Nov 10, 2008 | 02:40 PM
Koopa's Avatar
Default Hot Cams
Ya, think you supposed to remove the decompressor.
Old Nov 10, 2008 | 03:59 PM
Default Hot Cams
I replaced cams on a brute force once (Hot Cams) and they came with the centrifical decompressors.
Old Nov 10, 2008 | 04:10 PM
Koopa's Avatar
Default Hot Cams
On the EX you remove the decompression plug and spring off of the cylinder head. It's not needed.
Old Nov 10, 2008 | 04:20 PM
Gagt518's Avatar
Default Hot Cams
Okay thanks. Whats a good site where i can buy a OEM timing chain tensioner?
Old Nov 10, 2008 | 04:28 PM
Koopa's Avatar
Default Hot Cams
I'd try hondaparts-direct.com.
Old Nov 10, 2008 | 10:26 PM
700V-fla$h^.^'s Avatar
Default Hot Cams
Don't know about the chain tensioner. I do know that stage 1 is a direct drop in and most stage 2-3 cams require different valves. The cams can give you alot more power or destroy your motor if it does not have what it needs. I would make sure you have all the facts before doing it. Are you doing it or is someone else doing it?
Old Nov 10, 2008 | 10:48 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Default Hot Cams
Stage II Hotcams are drop in cams and do not need different valves. I would also question why a new chain tensioner is needed. Get an explaination from your mechanic.
