LTZ50 - No Power - Wont move
Old Nov 10, 2008 | 03:33 AM
snifter's Avatar
Default LTZ50 - No Power - Wont move
I bought my 4 year old a 2006 Suzuki LTZ50 and cannot get this thing to run right. It ran right for about 10 minutes when I first bought it and then the cdi went bad. The original owner did no mods to it and his kid rode it 3 times. It looks brand new.
The bike starts and idles fine, but when you give it gas it just cuts in and out and will barely move. It wont move if I am sitting on it (165 lbs) and will barely move if I hold the throttle and walk with it. Never stalls, just wont move.
I have completley cleaned the carb, changed the plug, put in a new cdi box (stock), new battery, checked for compression. I have no idea what else it could be. Feels like something electrical making it cut in and out, but I guess not. I am at a total loss. Anyone ever heard of this? I've read all of the forums on this site about this little bike, but havent seen anything like this. Just the topics of gettting it more power.....i just need to get any power.
I hate to take it to the local dealer and have them charge me $80-90 an hour just to diagnose and do all the same things I have already done. I see the bill adding up real quick.
Old Nov 10, 2008 | 06:57 PM
AIRMOBILE101's Avatar
Check your cvt belt. It sounds like the belt is slipping. Also it sounds like the rollers are trashed.Either way, open up the cvt case and take a look.
Old Nov 11, 2008 | 02:49 AM
snifter's Avatar
Took it apart tonight and the belt and rollers are in great shape. Is there a way to tighten the belt?
Old Nov 11, 2008 | 10:41 PM
slayerz636's Avatar
Well, I saw your post, and i created a account to answer your question. I have a 90cc MAXFINE. Yeah, its a chinese knock off. It sat in the driveway for two years, not being able to start. After some kind of brain surge, i found out what happened to it. It was a seal on the left side of the crank shaft. Replaced it, adusted the carb, worked like new. But anyway, you defentally need to look at the clutch. When a small vehicle cant pull its own weight, its one of two things. A lack of compression, which you all ready ruled out, or a bad clutch. Im guessing that this is a auto?? Just remove the clutch, and spin it in your hand. Itll do one of two things; wont spin at all, or will spin really, really, really smooth. Eiether of these things will point to a bad clutch. I know this because i work in a atv shop. (scottmotorsports.net) We see things like this all the time in the shop, and its really an easy fix. Email me with any questions.. slayerz@bellsouth.net
"sometines the young know as much as the old; im only fifteen"
Old Nov 12, 2008 | 10:17 AM
Heres an idea that I do with my son's Kawi. Take off the cvt cover somehow while the bike is running. Jack up the rear off the ground. Watch the belt while your giving it gas. The belt should travel higher as the engine speed picks up. The clutch should move also. If the clutch isnt moving, then like mentioned above, it might be bad, or it has a bad torque spring.
Old Nov 12, 2008 | 10:22 AM
Oh, one last thing.Check your spark arrestor,if its clogged up,it might be just enough for not letting that thing move.
Old Mar 27, 2021 | 01:50 AM
Naturalblaq's Avatar
Default Did anyone figure this out?
Having the same problem LTX 250 with drive shaft
TJSwear
May 30, 2017 11:35 AM
rjdreww
Jun 29, 2016 08:15 PM
Mikesohio
Jul 26, 2015 10:51 AM
ranmic
Jun 10, 2010 09:18 PM
