400EX smoking
Old Nov 11, 2008 | 03:54 PM
440EX2002's Avatar
Default 400EX smoking
My 400EX smokes when you run really hard, if you just putt around it doesn't smoke at all, it also smokes the worse once it is first started in the morning after it has sat all night. thanks and please help
Old Nov 11, 2008 | 06:58 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
Usually valve seals on 400ex.
Old Dec 26, 2008 | 06:35 PM
bmxerboy33's Avatar
what color is the smoke? if its white smoke its valves. if its black smoke it rings. hope i helped
Old Dec 26, 2008 | 08:05 PM
Koopa's Avatar
What if it's grey???
Old Dec 26, 2008 | 09:31 PM
cody450r's Avatar
yea koopa ur gay
Old Dec 26, 2008 | 11:38 PM
Williebee's Avatar
Grey color of spark plug means : Lean condition , Black color means : Rich condition and : Tan/Brown color means : Carb Jetting is correct !
Sometimes smoking can be a sign of exccessive carbon buildup inside the combustion chamber , heres a inexpensive test you can do to burn off the exccess carbon deposits and cleanup the fuel system as well ; add some SeaFoam to the gas tank and burn a tank of the mixed fuel through your engine !
You can get SeaFoam at most all Automotive Parts Stores , and some of your local WalMart SuperCenters for around $7.00 ; SeaFoam is a great product that really works great at cleaning the fuel , Carb and Combustion Chamber on all small engines 2 and four strokes , Gasoline and Diesel Fuel !
I would also reccomend a complete service of the engine , New Spark Plug , Clean and reoil the AirFilter and change the engine oil and oil filter ; and make sure you don't over fill the oil this can cause alot of problems !
I hope this will get your quad running the way it should , good luck and i hope everyone had a good Chirstmas ; and a happy New Year to evryone on the forums !.......
Old Dec 27, 2008 | 03:58 PM
Koopa's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: cody450r
yea koopa ur gay</end quote></div>
Very helpful there youngin'. Way to make yourself look like an a$$.
Old Dec 27, 2008 | 05:30 PM
bmxerboy33's Avatar
he didnt make himself look like an a$$. your just a smart a$$ so he said something about it.
Old Dec 27, 2008 | 10:51 PM
Koopa's Avatar
wow. ya, you guys can take jokes can't ya.
Old Dec 27, 2008 | 11:03 PM
bmxerboy33's Avatar
no not really! lol
