88 warrior - wont spark continuously-cdi or magneto?
Old Nov 13, 2008 | 04:57 PM
zx28's Avatar
Default 88 warrior - wont spark continuously-cdi or magneto?
I ve checked all wires and connecters, it will start if drug behind another fourwheeler and dropped into gear, but it still doesn't run right-- it misses like crazy---it s in time. The motor was running fine and my bro locked it up. I rebuilt it, new crank and magneto. after the rebuild it wont spark -(looking at the plug and turning over) -but every so often. I have thought that it was the cdi but i dont know why it would just go bad all of the sudden like that. Is there a way it could be the magneto? or stator? Im out of ideas and about ready to give up. any advice or opinions are greatly appreciated.
Old Nov 13, 2008 | 05:08 PM
91Warrior357's Avatar
most likely the stator is shot, very common on the warriors, you can perform an ohms test on it to see if its ok, also make sure the parking brake sensor is disconnected and that the ign. coil isnt badly dry rotted or something
Old Nov 13, 2008 | 05:12 PM
zx28's Avatar
alrighty i ll try that- how many ohms should i be getting-- (never done an ohms test)
Old Nov 13, 2008 | 06:41 PM
warriorslayers's Avatar
First off does that starter roll the motor over, and your just not getting spark... Sencond if you think your CDI is in working order make sure that it's grounded out very well.... Second make sure sencondary and primary wires are not damagd for the CDI, The CDI must be grounded out GOOD Make sure the CDI ground wire itn't corroded...
Old Nov 14, 2008 | 12:12 PM
zx28's Avatar
yes the starter rolls the motor over, and it will only spark randomly- and weak when it does--if i hold the plug it doesn't shock me very hard like it would it everything was working right.
Old Nov 14, 2008 | 12:27 PM
Evasiveone's Avatar
My money is also on the Stator.
Old Nov 14, 2008 | 06:32 PM
i cant member what ohms it should be i think it should be around mid 200's but when u test it i think u gotta test one pin on the connector and one pin on the second connector, theres a certain sequence that you have to test it in order to get accurate results
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
