Blaster has new front brakes and been bled, still no brakes
Old Nov 16, 2008 | 08:14 PM
440EX2002's Avatar
Default Blaster has new front brakes and been bled, still no brakes
I just installed new brakes on the front of a 2006 Blaster a week ago and they worked great, and now all of a sudden they stopped working,
what is my problem? Please HELP!!!
Old Nov 16, 2008 | 08:34 PM
thepandaman's Avatar
check the lines, check the adjustments, also go to blasterforum.com and ask around. they are alot of help
Old Nov 16, 2008 | 08:36 PM
91Warrior357's Avatar
sounds like they must have bled down or leaked out fluid. make sure everything is snug when u bleed them again.
Old Nov 16, 2008 | 08:57 PM
440EX2002's Avatar
when i try to bleed them the right front brake got all air out, and strait fluid, but the left side, i cant get
any fluid at all, my brake has no pedal at all,
Old Nov 17, 2008 | 12:37 AM
Traildad's Avatar
It could be a problem with air in the lines or a problem with the master cylinder.
Old Nov 17, 2008 | 06:47 PM
warriorslayers's Avatar
I would be shooting for the Master Cylinder... Get some more brake fluid and just keep trying to bleed them, before you go and change the pricey Master Cyl... Oh ya It helps to have an extra hand for bleeding the brakes LOL...
Old Nov 17, 2008 | 10:20 PM
440EX2002's Avatar
i removed the master cylinder and held my finger over the hole which the brake line goes, and i cant get very much pressure,
Old Nov 18, 2008 | 07:37 AM
cadillacdude1975's Avatar
i would have the master cylinder replaced. bleed the system again and you should be good to go.
Old Nov 18, 2008 | 09:25 PM
Traildad's Avatar
It is also possible that you have air in the master cylinder. When you buy a new master cylinder for a car you need to do a bench bleed. You hook up a couple plastic hoses where the brake lines go and put the other end in the brake fluid reservoir. Then you pump it until no air goes through the plastic hoses. This clears the air out of the master cylinder. You might try this before you replace the master cylinder.
Reactant
Mar 30, 2022 02:08 AM
Frisky2050
Apr 9, 2020 11:19 AM
joeyupton
Jul 14, 2015 11:51 AM
timster911
Jul 13, 2015 01:57 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
