Oil Capacity Blaster Engine Oil ? ? ?
Old Nov 16, 2008 | 09:03 PM
440EX2002's Avatar
Default Oil Capacity Blaster Engine Oil ? ? ?
how much oil does the crank case hold of an '06 Blaster?
Old Nov 17, 2008 | 10:32 AM
95wolv's Avatar
I don't recall any 2 stroke needing crankcase oil, do you mean transmission oil? there should be an add hole bolt to refill after draining, but you definately don't want to be putting oil in the crankcase of a 2 stroke, it will smoke like a fog machine, and probably not run very well.
Old Nov 17, 2008 | 10:22 PM
440EX2002's Avatar
i'm talking about the side of the engine there is a dipstick on my blaster,
I normally add a quart of Pennzoil 10W-40
Old Nov 17, 2008 | 10:46 PM
Raptor450's Avatar
I think it only holds about 3/4 of a quart. It would just be the transmission oil on a Blaster. Some people use transmission fluid instead of oil, like B&M trickshift.
Old Nov 18, 2008 | 12:23 AM
440EX2002's Avatar
Is it safe to use just regular motor oil?
Old Nov 18, 2008 | 02:00 AM
hotblooded's Avatar
I do use Amsoil 4 stroke oil and the ml of oil it requires should be labled right by the hole where you put the oil in the gear case.
Old Nov 18, 2008 | 02:11 AM
Raptoryfn660r's Avatar
RIP Dear Friend
Its been a decade or so give a little since I was on a Blaster but doesn't it say right on the right upper side case 650 CC'S , capacity near the fill hole? That would be about 22 oz's of oil. Its on the same side as the sight glass or fill it up on the upper line on the sight glass. 10w30, non star burst on the container is fine as far as the oil.
Old Nov 18, 2008 | 02:32 AM
hotblooded's Avatar
Thats what I meant I just couldn't remember the exact amount it said on there.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Frisky2050
Apr 9, 2020 11:19 AM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
joeyupton
Jul 14, 2015 11:51 AM
