TM/HSR CARBS
Old Nov 17, 2008 | 04:33 PM
YAMASUXHONDUST's Avatar
Default TM/HSR CARBS
What is needed to run tm/hsr carb in ways of throttle cable or will old one work its in the truck bouncin this way just needed to know
Old Nov 17, 2008 | 05:13 PM
jsimonh's Avatar
You can use the stock cable and thumb throttle. The cable needs to be modified a little but nothing to major. Alot of people like the stock cable over the RW anyways.
SilverBomb's Avatar
SilverBomb has got an Addiction!
I hooked my stock cable and right to my TM45 and it works like a champ. You just need that brass fitting that the cable goes into on the stock carb because it fits right into the TM. You might need to adjust the cable a little but that's as easy as twisting the adjuster on the thumb throttle [img]i/expressions/face-icon-small-happy.gif[/img] Also, pulling the stock cable out of the threaded piece on the stock carb is a pain, I had to cut mine but if you can yank yours out without cutting that, even better.
Old Nov 17, 2008 | 08:52 PM
Thanks for the help!!!!!!!!!!!
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
