Building your own cam?
Old Nov 17, 2008 | 09:42 PM
SweetWheelieGuy7's Avatar
Default Building your own cam?
Hello everyone? have you heard of anyone building and custom grinding there own cam? i've heard if you do it corectly you can add lift and even change the duration by welding, grinding, and pollishing the lobes... any one ever heard of or tried this??
Old Nov 17, 2008 | 10:50 PM
beefy46172's Avatar
Loves To Ride!
Oh, I suppose you could do it, but you have to know precisely what you are doing and have all the right equipment to do it. You have to know how far you can push it with the cam, what is too much for the current set up. Its best just left to the companies that already have done all the research for you and mass produce with all the right equipment.
Old Nov 18, 2008 | 04:37 PM
91Warrior357's Avatar
i think my dad knows how to do it but i dont think its really worth the time trying to do so unless you got extra cams, alot of time, and you like to tinker with things
Old Nov 18, 2008 | 07:39 PM
i'm actually going to school for engine building, so i know alot about v-8s and stuff quads are kinda new to me and i'm really intrested in them! i have all of the right equipment and just wanted to get some info on it... all of the info is great, but the head i have is all ported and polished flowbench tested and performance valve job with a 3angle cutter, valves are back cut, and head is resurfaced, so far! its going on an 88 warrior.
Old Nov 19, 2008 | 03:59 AM
skj283's Avatar
i dont think you could get even close to precise with a grinder and a welder. i would say you would be better off to send one off and get it reground. i would say that would just not be a good thing to try, if it takes a lobe out its gonna put a bunch of metal in your motor.
Old Nov 19, 2008 | 08:31 PM
bigned1904's Avatar
i would only trust a very high end shop to custom grind me a cam. such as kenz cycle in az. i know they do custom grind megacycle cams.
Old Nov 19, 2008 | 11:07 PM
Raptor450's Avatar
Yep, for $125 + 100 for valve springs you can buy a cam that has already been designed, engineered, tested, and dynoed. I would say that's cheap compared to what could screw up if a custom cam was not made properly. Is 1/2 horsepower worth all of the extra trouble?
Old Nov 20, 2008 | 12:07 AM
bigned1904's Avatar
btw what kind of quad are you looking for a cam for? someone around here might have some cam know how for your specific quad.
Old Nov 20, 2008 | 11:24 AM
oops! i forgot you can't read minds! ha its an 88 yamaha warrior and of course i'm a big block guy when it comes to v-8 engines, so i want lots of TORQUE!!!
Old Nov 20, 2008 | 06:06 PM
well....then maybe if you stretch the frame a little bit you can fit a 289 in there...lol
