96 honda foreman trx 400
Old Nov 20, 2008 | 09:11 PM
skitz80's Avatar
Default 96 honda foreman trx 400
my atv will not move when i put it in any gear, .I took apart the rear differential and noticed the ring gear was a liitle worn i was wondering if anyone new if that was the problem or maybe it was the tranny?
Old Nov 20, 2008 | 10:50 PM
HondaMechanic's Avatar
Should still pull with front differential .. I would check manual clutch adjustment and if that's ok then I'd remove the clutch cover and check the manual & centrifugal clutch/s ..
Old Nov 22, 2008 | 07:38 PM
skitz80's Avatar
the front differential doesnt work. but when i put it in gear i can hear it engage then the part that connects to the ujoint turns so does the rear diff but when i had the tires on they did not turn at all. so iam thiking that the ring gear is bad its pretty worn i think its original would that be my problem? or do you think that its still my clucth or maybe both?
Old Nov 22, 2008 | 11:16 PM
The 400FW only had 1 seal on the drive shaft coupler on the front drive shaft , water would get in and rust the splines then they would strip ...
On the rear if you start the bike put it in gear , remove the rear differential oil cap , is the ring gear turning but axle not turning .. ? .. If so then the axle is stripped .. But if the drive shaft is turning but the ring gear & axle are not turning then problem is with the pinion ..
NewGuy2481
Oct 6, 2015 05:54 AM
Johnny Mac
Sep 27, 2015 08:33 PM
stcspiderman
Sep 13, 2015 05:15 PM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
Jason Campbell
Sep 7, 2015 02:25 PM
