trail boss problems
Old Nov 21, 2008 | 01:12 PM
monkeywrench321's Avatar
Default trail boss problems
hello im a first time quad owner and happened to get a polaris. i have a 94 trail boss 250 i just rebuilt last weekend. runs good has pleanty of power. my problem now is the chain popped off and got stuck in the front sprocket. i was putting the reverse on and trying to free it that way. well i ended up pulling the chain out with my hands and the screw driver. the chain was messed up bad so i replaced it. now it bogs in gear and smells like rubber burning real bad. im guessing the belt needs to be changed but do you think its smelling likie that becouse off the gear case is messed up. i hope not. anyway when i roll the polaris back and fourth in gear it sounds good and the gears are moving very nice and easy when the polaris isnt running. but it does go but not as good as it did
Old Nov 21, 2008 | 01:32 PM
MECHANIKE's Avatar
YEAH I WOULD REMOVE THE BELT COVER.LET US KNOW WHAT YOU SEE.BELT IS FAIRLY CHEAP.
Old Nov 21, 2008 | 02:40 PM
o.k. ! i pulled the belt system off the bike the clutching of the rear big pully has three little triangle clutch pads in it. they where all broken. i think it was binding the rear pully when the little pads where slinging around inside the pulley. so the front pulley was going faster then the rear pulley causing my built to burn.
anybody know ware to get these little clutch pads.
Old Nov 21, 2008 | 03:54 PM
o.k. i replaced the three little plastic pieces in the clutch. replaced the belt and that was the problem. so i tested it out and seems like it has more power than before so im very pleased.
Frisky2050
Apr 9, 2020 11:19 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
ranvette
Jul 4, 2015 06:13 PM
yambam13
Jul 4, 2015 01:49 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
