K&N Air Filter
Old Nov 22, 2008 | 01:32 AM
Turtle1231's Avatar
Default K&N Air Filter
I just purchased an 05 Honda Rubicon and wanted to know if a K&N air filter boosts the performance any. Any pros/cons of using K&N?
Old Nov 22, 2008 | 01:57 AM
cherokee99's Avatar
IMO dont use a k&n. they really do let in more junk than a foam filter. when i bought my foreman it came with a k&n, i switched to a UNI and have seen 0 diffirence in preformance. with the UNI its piece of mind that im getting the best filtration, and not letting larger particles of dirt threw like k&n dose.
its proven that k&n has more airflow, because it dosnt filter as fine as foam.
Old Nov 22, 2008 | 05:09 AM
JeffinTD's Avatar
I also would not use a gause type filter on something that lives in the dust and grit...
I think the airbox restricts flow more than the stock foam filter does, anyway.
Old Nov 22, 2008 | 09:28 AM
crazy old mudslinger's Avatar
i posted a question a few weeks ago akin if the k& n is worth is or not & most agreed on the uni , c if u can pull up my post ( k& n is it worth it)
Old Nov 22, 2008 | 10:49 AM
Turtle1231's Avatar
Thanks guys
Old Nov 22, 2008 | 05:44 PM
firehog's Avatar
Ideally: foam for dirt and k&n for sand.
Old Nov 22, 2008 | 07:13 PM
JeffinTD's Avatar
Here is an interesting article where they compared various air filters. Granted, it is for a duramax truck, but it is the only independent test of assorted air fliters using ISO testing equipment that I have come across.
In a nutshell, all the aftermarket filters flowed better than stock when clean, but after a little bit of dust was introduced the stock filter flowed better. The stock filter also let the least dirt pass through.
ISO 5011 Air Filter Comparison
Old Nov 22, 2008 | 07:26 PM
firehog's Avatar
Thanks Jeffin, that was very informative. I think alot of people are duped into believing an air filter will give them more power or better filtration when they really don't. I use them so I can clean them often and they will still work if they get wet.
Old Nov 22, 2008 | 07:34 PM
jrafter's Avatar
yea i got a uni because its a good filter and easy to clean......but i read somewhere that the stock was just as good at flowing air.
Old Nov 22, 2008 | 08:18 PM
JeffinTD's Avatar
It sure doesn't hurt to have two filters for each machine, so you can always have a clean one on hand and ready to go, w/o having to wait for solvent to dry...
