Oil change help!!!
Old Nov 23, 2008 | 04:39 PM
edoppelt's Avatar
Default Oil change help!!!
Cant get all the oil to drain on my 2005 ds650x. Bleed screw wont unscrew. Help....what can I do?
Old Nov 23, 2008 | 06:06 PM
McKay5858's Avatar
do you mean the screw in behind the oil filter?
Old Nov 23, 2008 | 07:08 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
On an 05 there would be no need to mess with the bleed screw. They rectified that problem years ago. Is there still oil in the tank? You'll get quite a bit from there, but you will get more than a 1/2 quart from the case as stated in your other thread.
Don't forget to clean the screen in the tank, and the magnet on the plug.
Old Nov 28, 2008 | 11:38 PM
MRDS650's Avatar
Canadian and Proud of it !!!
Try removing the hose from the oil tank that connects behind the cylinder to drain the rest of the oil.
Old Nov 29, 2008 | 10:20 AM
650Rotax's Avatar
if you remove the hose from the tank to the case, make sure you bleed that same hose before you try to start it. I always turn off the fuel, flip the kill switch, and pull one spark plug and crank it until the oil light goes out before starting, already fried one crank, it's cheaper than rebuilding again.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Alex G.
Sep 11, 2017 11:38 PM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
