Help Fixing Banshee
Old Nov 26, 2008 | 06:51 PM
MonsterBanshee's Avatar
Default Help Fixing Banshee
yo wut up.my name mo an i have a problem with my 04banshee (my baby grl)...i went mudding one weekend an the day after she wouldnt start...now after i went an change the plugs it still wont start. The only thing that starts it up is pushing it like 4 or five times down my drive way? Can Any Body direct me in the direction Thank you
Old Nov 26, 2008 | 08:59 PM
91Warrior357's Avatar
its most likely got low compression. how much time have you put on it? stock pistons i assume? id do a compression check, being ignorant to start can be low compression or maybe it might be running lean due to cold weather
Old Nov 27, 2008 | 06:31 PM
Do you think it could be the carbs? Befor I go an check the compressin. An basicly your tellin me 2re-build Motor?
Old Nov 27, 2008 | 06:35 PM
But if it's the compression how come I can push or pull start I??? By the way Happy Thanks Giving
Old Nov 27, 2008 | 06:50 PM
well doing a compression check is easier then messing with your carbs, but you can do a plug chop to see how its running, to do so you want to warm your bike up on old plugs then switch to new plugs and run full throttle to 6th gear then pull clutch in and hit kill switch then pull plugs and see what they look like, to be exact you want a 2mm brown smoke ring on the bottom of the white part(porcelin) on the plug, you actually have to cut the side of your plug to be able to see this ring because its on the bottom, but if you dont see a brown ring then its prolly too lean and if its got alot of brown around it then its too rich heres an example Name:  Plugs2.jpg
Old Dec 1, 2008 | 10:56 AM
[img]i/expressions/face-icon-small-cool.gif[/img]
Old Dec 1, 2008 | 11:08 AM
thank you for the info on my banshee....but i have some other quetions that maybe you could anwser. yzf 125 dirtbike is it all that everyone makes it? i mean can it keep up with a stock an or a banshee? an the new yzf 450 quad it that fast? or good power?
ultangler
Nov 30, 2024 01:35 AM
95wolv
Sep 27, 2024 12:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Matt123
Sep 29, 2015 01:29 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
