250ex help!!
Old Nov 27, 2008 | 05:48 PM
brungardt's Avatar
Default 250ex help!!
i have a 250ex that when i start it the valves are ticking and it smokes on hard acceleration... once the motor is warmed up(20min or so) the ticking stopes and the smoking stops....the only thing i can think of is the oil pump is worn and its hard to pump the oil until its thiner.... the comp. is 175 psi.. thanks
Old Nov 27, 2008 | 07:01 PM
700 sportsman's Avatar
you probably need to adjust the valves, and also the smoking, may be from the valve seals goin to pot
what year is it
Old Nov 27, 2008 | 07:12 PM
brungardt's Avatar
its a 2002.... if it were the valve seals would it smoke all the time??? or just when cold
Old Nov 27, 2008 | 07:30 PM
did you buy it new, and have the valves ever been adjusted, my buddy has an 03 and we just adjusted the valves and they were pretty far out of wack
here's the link to a thread that talks about valves and valve seals, I know its a 400 ex but it's the same concept
Old Nov 27, 2008 | 07:50 PM
brungardt's Avatar
um... i bought it used but we had to put a new oil pump chain on it so we had to retime it... could that through the valves off?? JW
Old Nov 27, 2008 | 07:51 PM
brungardt's Avatar
oh... and before we put the chain on we adjusted the valves.... im thing though it has something to do with oil
Old Nov 27, 2008 | 08:15 PM
Y2daT's Avatar
worn valve guide seals will cause smoke when cold then clear up when warm.
if it continues smoking after warm up then its time to go in and do somthing ...until then ride...have fun and keep an eye on it ...you may be able to get a couple more years before the valve guide seals go to smoking all the time..and the burnt oil wont hurt much other than the spark plugs
.....and youll hear the valves if you listen for them ,but if they are abnormaly loud adjusting them isint a bad idea...and you can renew your valve guide seals while you have it apart
Old Nov 27, 2008 | 08:23 PM
brungardt's Avatar
ok great...thanks for the help..... ill just keep riding it then.. and do something about it when i have some time and money....
hondarider1234
Jul 21, 2015 11:53 PM
cSchwartz
Jul 9, 2015 02:40 PM
Rider252
Jul 6, 2015 03:37 PM
Jake55
Jun 29, 2015 06:43 AM
DSAPP
Feb 1, 2001 09:49 AM
