Honda ATC 110 Compression Problem
Old Nov 29, 2008 | 04:44 AM
ShotGun John's Avatar
Default Honda ATC 110 Compression Problem
I Have A Honda ATC 110 With No Compression (Ok Very Little Compression)... I Have Tried Engine Restore, Seafoam, 2-Stroke Oil... And A Bunch Of Other Stuff... Any Ideas??? I Am Completely At A Loss... I Am Wondering If It Might Be Valves, Or Piston Rings.... But I Have No Clue...
John
Old Nov 29, 2008 | 04:49 AM
I Don't Know If It Matters Or Not But It Is A 1985 All Original 110 ATC
Old Nov 29, 2008 | 06:22 AM
Sorry I Am New To This Forum... I Am Also New To 3-Wheelers... I Have Never Worked On A 3-Wheeler Let Alone A 4-Stroke.... I Am/Was A 2-Stroke Dirt Bike Guy...
Old Nov 29, 2008 | 02:27 PM
I Got This Machine From Some Dude Who Was A Complete Jerk.... He Showed Me It Ran... Didn't Tell Me About The Problems With It.... So I Got Ripped Off With A Machine That Ran For 10 Min And Died... Because Of Compression.....
Old Nov 29, 2008 | 06:44 PM
HANDM's Avatar
Lets assume that you have actually checked the compression, if it is not within specs, new rings are in order. Go to your local honda cycle center and get em, or online even. get a Clymer manual while yer at it
If'n it ran before it should run now, with weak compression or not, clean or replace the spark plug, change the gas, clean the air filter, check for spark, shoot some starter fluid into the plug hole, install plug and it should fire or pop at least.
Had the same trouble with a 01 KX 85 that had sat for two years or more, replaced carb, new plug, fresh properly mixed fuel, clean filter, oil change now it runs great and the power band is downright insane, had to install a header spacer/ restrictor so I can ride the thing in my woods and tame it a bit
Old Nov 29, 2008 | 10:34 PM
ok thanks.. well when i did get it to pop with the starter fluid... but thats all everything else is fine... replaced the oil, airfilter, new premium gas, new plug with lots of spark...
Old Nov 30, 2008 | 12:55 AM
i think i might just get the top end rebuilt.... any suggestions on where to go??? (i live in brevard county florida...)
Old Nov 30, 2008 | 02:19 PM
HANDM's Avatar
I bought, but not yet recieved a top end rebuild kit from, http://stores.ebay.com/G-H-Dis...Z0QQftidZ2QQpZ2QQtZkm
you have to send em your cylinder and they machine it and match it with piston, pin, rings and gasket kit, not sure about your model though, check it out
$150 or so
Old Nov 30, 2008 | 02:25 PM
thanks alot!.. ima order one asap
