Honda ATC 110 Compression Problem
No compression can be rings stuck in the piston grooves.In this case just running it for a while will loosen them and give you your compression back.I would suggest getting a manual and going through all the maintanance procedures and get it to run again. A stuck or burnt valve can cause little or no compression also.
