jet question
Old Nov 29, 2008 | 07:21 PM
crazy old mudslinger's Avatar
Default jet question
what does the pilot jet n a 400ex carb control & should i have put a main jet n instead of a pilot if its runnin lean
Old Nov 30, 2008 | 02:28 PM
go-hard-or-go-home's Avatar
your pilot controls the start of your engine in most ways. for instance...if you wanted more HP out of your carb and atv, you could remove the choke. after so, it would have a time starting. so u put a bigger pilot in to fix that prob. cold or hot it will fire right up.
now if your to lean, you need a bigger jet. 146-148 is stock. get a fmf jet kit and try all the diffrent jets. stock bike with pipe try a 150-155. rebuild aith pipe, try 175-180, and so on.
hope this helps...
Old Nov 30, 2008 | 02:34 PM
thanks , ill give it a try
Old Nov 30, 2008 | 02:38 PM
me & my brother both had one and his choke was removed , mayb thats why he had alot more on the bottom end
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
