WHAT IS THE BEST KIND OF BORE KIT FOR MY 05' 400EX
Old Dec 1, 2008 | 05:35 PM
Honda400-4-ever's Avatar
Default WHAT IS THE BEST KIND OF BORE KIT FOR MY 05' 400EX
WHO MAKES THE BEST KIND OF BORE KITS AND WHAT TYPES ARE THE BEST FOR MY 05' HONDA TRX400EX
Old Dec 2, 2008 | 02:04 PM
go-hard-or-go-home's Avatar
je makes a great piston for the 400ex and any other engine! weisco is bottom line and the cheepest, but will do fine for a 400! if you want performance and quality check out cp pistons! there the best ever, and not just my opinion. check the web site!
Old Dec 2, 2008 | 06:48 PM
what brand do you have on ur 400ex?
Old Dec 2, 2008 | 07:57 PM
crazy old mudslinger's Avatar
why do u think wiesco is bottom line ? ive never had any problem with them & they have ran great for me , but i dont keep up on them so i may have missed the boat & may need to try something else next time i rebuild somethin
Old Dec 9, 2008 | 12:38 PM
weisco is a great piston. just bottom line. its like...mcdonalds has great burgers, but youll get a better one at a steak house. question was what do i have... i run CP pistons in everything i own!!!! for instance, you can get a complete weisco set ( piston, rings, gaskets, and o rings ) for $89.00! go to CP, you can get custom pistons made just 4 your bike! ceramic coating below the rings, and kevlar top to prevent pre ignition spark damage!! but is gonna be anywhere from $200.00 and more just for the piston. there x forged for stability! they are lightr that any piston. there is just so much to learn about them. besides...you get what u pay for and the piston takes more wear than any other thing in the engine!!
check em out at CP racing
Old Dec 9, 2008 | 12:43 PM
CP Pistons offers over 120 shelf part pistons featuring Honda, Yamaha, Suzuki, Kawasaki, KTM and others for your street or powersports application. Each of these pistons was designed through extensive research and development with the cooperation of some of the biggest names in motorsports. These pistons are available in standard size or big bore kits and are compatible with higher lift cams and oversize valves. Each of these pistons incorporates an "X" style forging for addition strength, durability and weight reduction. Along with the our standard aftermarket pistons, CP offers full race pistons for certain applications. These are custom pistons that are available on the shelf. The race pistons are a lightweight, high compression version that comes standard with skirt coating and gas ports. All of our pistons represent the highest quality and are engineered for maximum power.
CP offers a wide variety of forgings made specifically for you application. Each piston is designed using sophisticated 3-D modeling software and manufactured with advanced 5-axis techniques making you piston the lightest and strongest piston on the market. See custom piston section for more details.
Shelf part features include
Double forced pin oilers Fully CNC machined
Accumulator Grooves Pick-lock grooves
Anti-Detonation Grooves X style forgings
CPW Lightweight pins High performance rings
Millenium oversize cylinders are available for certain applications. See cylinder chapter under catalog section for more information.
Cometic gasket kits are available for all shelf parts. See gasket chapter under catalog section for more information. Gasket kits are listed in the catalog to correspond with your application.
Old Dec 9, 2008 | 11:08 PM
ive never heard of them , but ill check into them , do u have to order them from the company & do u have to run racing fuel , since they r high compression
Old Dec 21, 2008 | 05:29 PM
bmxerboy33's Avatar
you will have to run 93 octane but hey at the least its still pump gas.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
