Replacing Stock parts
Old Dec 1, 2008 | 07:13 PM
MonsterBanshee's Avatar
Default Replacing Stock parts
1-i have a new tire that is 20x10x9 (rear) what size rim will that fit on?
2-How many lnks are in a banshee chain linkage?
3-where can i find a aftermarket starter coil
4-how to get my banshee to start up in 1-2 kicks?
Old Dec 3, 2008 | 06:45 PM
91Warrior357's Avatar
1- yes i believe u can use 10-9 and 11-9
2-i think its 98 or 100 but u can count just 2 be sure
3-Ricks and Nology makes ok Igntition coils at bikebandit.com and farmandsandtoys.com, i recommend Nology
4- to get your banshee to start that easily ud need good compression, syncronized carbs, good spark, and correct jetting for where u live.
Old Dec 4, 2008 | 02:07 AM
Just moved to the ct area.....cold as ****
Old Dec 4, 2008 | 04:58 PM
yea its prolly running lean now then
Old Dec 4, 2008 | 11:16 PM
So if I jet it will it run better
Old Dec 4, 2008 | 11:48 PM
yea if u can confirm that it is running lean, and then you go up a mainjet size or two until its got the 2mm smoke ring then it deff should run better.
Old Dec 4, 2008 | 11:54 PM
tricksh@t's Avatar
ok the i dont know were the ct area is but is it a higher altitude than were the bike came from
Old Dec 4, 2008 | 11:59 PM
Ct area right nxt to new York city..... An If I go up in the jet will it run str8 or like **** wen I gets warm again?
Old Dec 5, 2008 | 12:02 AM
tricksh@t's Avatar
are you at a higher altitude than you were
Old Dec 6, 2008 | 05:06 AM
Well I came from the south so ya
hugemoth
Jul 20, 2020 03:28 AM
bikedad3
Jul 2, 2015 02:15 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
Matt Ruszkiewicz
Aug 2, 1999 04:42 PM
