What is the biggest tire size for the back of a Warrior?
Im gonna need new tires by about christmas and i mostly use my quad as to play around off road and go muddin rarely ever on concrete or gravel.
Im thinkin about some mud tires but dont know what the max tire sizes are or anything like that so hit me up if you know whats possible
Most people run no bigger than 22x11x9 on the Warrior. You could probably squeeze some 23x12x9 on there, but if you need to go that big you need to sell the Warrior and buy a 4x4.
My freind put 24-11-10 Swamp Witch with 1-1/8th" lugs on the back of a 2wd 300 Kawi Lakota with no issues. Stock the ATV had 22-11-10.
He lost a bit of acceleration and top end but he gets through spots easily that once got him stuck and the rear sprocket does no hit the rocks as often as it use to.
u can usually got 1-2" taller with a small amount of powerloss and be ok, tire weight also plays a big roll on power loss, for example a 25" mudlite weighs around 15lb each while a 25 mudbug is around 20lb, that 10lb total can make a diff
When I bought my warrior it had 25/12-9 on the back of it. It was a little jacked up in the rear but really could go thru some mud. Not what I was looking for though.
Okay my tires are 23x10x9 i was confused the other day when i said what size they are
The tires just look real narrow though are the factory rims not very wide?
Hankey Pankey
26
Oct 18, 2020 03:50 PM
Mphillips
Jul 29, 2015 08:53 PM
