What is the biggest tire size for the back of a Warrior?
Old Dec 2, 2008 | 12:26 AM
69Purple's Avatar
Default What is the biggest tire size for the back of a Warrior?
Im gonna need new tires by about christmas and i mostly use my quad as to play around off road and go muddin rarely ever on concrete or gravel.
Im thinkin about some mud tires but dont know what the max tire sizes are or anything like that so hit me up if you know whats possible
Old Dec 2, 2008 | 11:41 AM
Politically Incorrect's Avatar
Most people run no bigger than 22x11x9 on the Warrior. You could probably squeeze some 23x12x9 on there, but if you need to go that big you need to sell the Warrior and buy a 4x4.
Old Dec 2, 2008 | 11:51 AM
TLC's Avatar
TLC
My freind put 24-11-10 Swamp Witch with 1-1/8th" lugs on the back of a 2wd 300 Kawi Lakota with no issues. Stock the ATV had 22-11-10.
He lost a bit of acceleration and top end but he gets through spots easily that once got him stuck and the rear sprocket does no hit the rocks as often as it use to.
Old Dec 2, 2008 | 02:10 PM
Jeepsterbrad's Avatar
u can usually got 1-2" taller with a small amount of powerloss and be ok, tire weight also plays a big roll on power loss, for example a 25" mudlite weighs around 15lb each while a 25 mudbug is around 20lb, that 10lb total can make a diff
Old Dec 4, 2008 | 01:16 PM
69Purple's Avatar
Mine already has i 23x11x9 or maybe 23x9x11 but i just want wider tires they dont really need to be taller
Old Dec 4, 2008 | 06:33 PM
I know they make 23x12x9, but never seen any that are wider than that for ATV's.
Old Dec 5, 2008 | 02:43 AM
yea 12 is about wide as they make em
Old Dec 5, 2008 | 02:26 PM
Jeff_Super_S's Avatar
When I bought my warrior it had 25/12-9 on the back of it. It was a little jacked up in the rear but really could go thru some mud. Not what I was looking for though.
Old Dec 6, 2008 | 09:11 PM
69Purple's Avatar
Okay my tires are 23x10x9 i was confused the other day when i said what size they are
The tires just look real narrow though are the factory rims not very wide?
Hankey Pankey
26
Oct 18, 2020 03:50 PM
Mphillips
Jul 29, 2015 08:53 PM
Nelson
Jun 20, 2015 01:59 PM
BOBATVN
May 26, 2015 07:34 AM
lablover
Mar 12, 2000 04:03 PM
