need help with '86 trx 350 fourtrax
Old Dec 8, 2008 | 04:21 PM
ShotGun John's Avatar
Default need help with '86 trx 350 fourtrax
this machine has been sitting for years and hasnt been touched til the other day. when i got it it was in pieces so i put em all together and it ran (i changed the oil, drained and cleaned gas tank, cleaned carb, put a new fuel filter on it, and a whole bunch of other stuff) but it would run for a lil while idling then die or when you gave it gas it would bog down and die... and since i put a new fuel filter on it it is acting like its not getting any gas.... any ideas? what should the set screw settings be?
thanks for any help
John
Old Dec 9, 2008 | 12:56 AM
cherokee99's Avatar
sounds like a dirty pilot jet. its located outside the bowl, twords the engine. remove clean with carn cleaner and reinstall. remember to count the turns out/in it is. it could also b a partially clogged float valve. if you didnt take that apart before, i would do so. also check the float to see if its bad, hold it under water for a few seconds and see if their is any water inside of it.
Old Dec 9, 2008 | 01:18 AM
thanks a ton... its running perfect now!... uhmmm does anyone know how i can plug the hole where the starter motor was??? (cant afford one at this time... and need to plug the hole)
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
wendal
Sep 15, 2015 01:50 PM
Steeldon
Sep 8, 2015 10:51 AM
ScopeZ_
Jul 28, 2015 01:44 AM
