Carb help
Old Dec 8, 2008 | 08:29 PM
Sports500's Avatar
Default Carb help
Hi, I been trying to fix an 01 Sportsman 500 HO, and i had to drill the adjuster screw(34 on the image) out on the carb, because it was stripped.I have to figure out how i'm going to reinstall it after i get it.What exactly is the adjuster for?
Old Dec 8, 2008 | 11:26 PM
Sports500's Avatar
Default Carb help
Well I guess i have another question. Being that i had to drill that adjuster out will i be able to put a helicoil in it and get the adjuster to work properly or is it a better idea to get another carburetor.
Old Dec 9, 2008 | 12:34 AM
eggenz7's Avatar
Default Carb help
i doubt there is enough material left in the hole to get a helicoil in there. i would try to find a carb somewhere or might be able to use some jb weld to fill in the hole part ways then drill and tap that out. dont want to get too much jb in there just in case it clogs up a hole. just a thought.
Old Dec 9, 2008 | 12:58 AM
Sports500's Avatar
Default Carb help
What exactly is that adjuster? I really didnt mess up the hole i stayed on the adjuster screw and just broke it all apart.
Old Dec 9, 2008 | 01:09 AM
lovmudd's Avatar
Default Carb help
<div class="FTQUOTE"><begin quote>Originally posted by: Sports500
What exactly is that adjuster? I really didnt mess up the hole i stayed on the adjuster screw and just broke it all apart.</end quote></div>
I can't tell for sure but it looks like your idle adjustment screw. As you turn it in, it should lift your throttle slide to give more r's
You should be alright if you didn't mess up the threads too much.
<u>On a second look</u>, it looks more like a jet, either high or low, either way if you didn't mess the theads up and you can still get the new part to thread in you should be OK.
Old Dec 9, 2008 | 09:27 AM
Kerbbirds's Avatar
Default Carb help
Its the air-fuel screw needs set at 2 to 2.5 turns out
Old Dec 10, 2008 | 12:06 AM
Sports500's Avatar
Default Carb help
<div class="FTQUOTE"><begin quote>Originally posted by: Kerbbirds
Its the air-fuel screw needs set at 2 to 2.5 turns out</end quote></div>
Thanks, do you think i can repair the threads and get it to function properly?
Old Dec 10, 2008 | 09:45 AM
lovmudd's Avatar
Default Carb help
If you didn't mess up the threads too much, you may be able to use the new adjuster to straighten them out by repeatedly screwing it in out out of the damaged threads. Force the adjuster in a little deaper each time.
You may also find a tap or a thread chaser to clean up the treads, but I don't know what kind or size theads are in the carb. If you find one to work, you again need to be carefull about running it in too deep, and messing up the seat.
What I would be concerned about is if any damage occured to the seat by drilling out the old adjuster. If you ran the drill bit too deep into the hole, you might have messed the seat up, ruining the carb.
The bottom line here, is you don't have much to loose by trying to save it. The option of buying another carb is always there.
Good luck.
Old Dec 10, 2008 | 08:12 PM
Sports500's Avatar
Default Carb help
<div class="FTQUOTE"><begin quote>Originally posted by: lovmudd
Good luck.</end quote></div>
yea, I really can't mess it up again.
Old Dec 19, 2008 | 12:33 AM
Sports500's Avatar
Default Carb help
Well I got the carb kit in today, and the adjuster screws in about 3 turns then gets really hard, so im afraid to go further. I want to chase the threads because i can still see some of the gold adjuster pieces in there, But i have no idea what size tap i need.
]Anyone have a clue?
