400 04 sportsman overheated
Old Dec 9, 2008 | 12:31 PM
yaK's Avatar
yaK
Default 400 04 sportsman overheated
so...it overheated while plowing yesterday.....didnt [i origianly posted did ] hear the fan going.....where should i start?
thanks
p
Old Dec 9, 2008 | 12:45 PM
Groovy's Avatar
check ALL fluid levels.
Ensure the radiator is clean (if liquid cooled or with an oil cooler) and free of debris.
Old Dec 9, 2008 | 02:03 PM
yaK's Avatar
yaK
fluid levels were fine before it over heated......but i made mistake in the original post as i ment to say that i could not hear the fan going.....maybe it has ice or snow in it?
anyone no where to start testing to see if the fan works?
Old Dec 10, 2008 | 01:09 PM
yaK's Avatar
yaK
bump!
Old Dec 10, 2008 | 07:05 PM
94harley's Avatar
Non ECM model
The fan switch is on the bottom right rear of the radiator. The wires run straight up the side to the top. It's a 2 pin connector. jump those two wires. Fan should turn on(key on of course) If not, spin it by hand-is it smooth during rotation? Locked up?
Check the switch too, they were known to break wires.
ECM model
Fan is turned on by the thermal sensor on the left side of the cylinder head sending a signal to the ecm. It's a 2 wire connector on a sensor threaded into the head. It's an ohm test to diagnose it. This info is out of a 2005 manual, but i BELIEVE it's the same. Ask Old Polaris Tech maybe he could look it up for you, he's still at a dealership.
I believe this 2nd part is correct, but i quit the dealership before we saw to many heating issues(other than ECM's) Someone correct me if I'm wrong.
Old Dec 10, 2008 | 08:35 PM
yaK's Avatar
yaK
k....Im going to try and pull it apart tomorrow after it stops snowing. Thanks alot for the info.
Jenn1
Sep 8, 2015 09:16 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
cornermike
Jul 30, 2015 06:37 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
