04 raptor
Old Dec 9, 2008 | 12:43 PM
tstansbury's Avatar
Default 04 raptor
I have a 04 raptor with a 686 kit,full pipe and K&N filter.I have had it about 3 weeks it has ran great carberation seamed perfect. Then I cleaned the filter It was really dirty(probablly unrelated) the next day I started it up. It idals fine but as soon as you touch the throtle it just it pops and back fires and does not rev up. It will not warm up past this stage. The jets looked Ok starter fluid sprayed around outside of carb and boots had no effect new plug. Any thoughts thanks
Old Dec 9, 2008 | 02:41 PM
Politically Incorrect's Avatar
Default 04 raptor
Parking brake sensor. You could bypass it or jiggle the parking brake lever mechanism on the clutch lever perch, that may get it going for a while.
When the parking brake is 'on' the rev limiter is enabled. The sensors that tell the engine that the parking brake is on are junk. Most of the time the parking brake is off, but the sensors go bad and still enable the rev limiter. Do yourself a favor and get rid of the parking brake assembly and get a parking brake block-off plate. Who needs a parking brake on an ATV anyway?
Also make sure the reverse switch is not half-way engaged.
Old Dec 9, 2008 | 03:30 PM
tstansbury's Avatar
Default 04 raptor
do you know if you can disable the parking break sensor by unpluging it or jumping across it?
Old Dec 9, 2008 | 03:43 PM
91Warrior357's Avatar
Default 04 raptor
i think you should be able to unplug it and then plug it into or itself and just let it hand down.
Old Dec 9, 2008 | 05:33 PM
tstansbury's Avatar
Default 04 raptor
that was the problem Thanks for the help. You gota love the specific advise you can get on forums.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
