Sportsman 500 no 4wd in reverse?
Old Dec 10, 2008 | 09:50 AM
willy888's Avatar
Default Sportsman 500 no 4wd in reverse?
1998 Polaris Sportsman 500, the 4wd works fine in forward drive but, the 4wd won't work in reverse. It use to work when I engaged the reverse override button but, now the rear tire are the only thing spinning, 2wd only. Can anyboby help troubleshoot this?
Old Dec 10, 2008 | 07:49 PM
user493's Avatar
Moto Psycho
Welcome to the forum *****. Does the rev override work at all? Can you go fast in reverse when you hold the button? If not, that's where your problem is, the switch or wires.
Old Dec 11, 2008 | 11:53 AM
willy888's Avatar
JumboFrank,
Yes, the rev. override works fine. I can go fast in rev but it is only in 2wd while the 4wd button is engaged. It started to get flakey last winter, somtimes it would engae in 4wd in reverse and somtimes it wouldn't. If I would just keep pushing the rev override it would eventually engage 4wd and away I would go. This year I can't even get it to engage in 4wd in rev at all.
Old Dec 11, 2008 | 04:34 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
check the contacts of the wire to make sure thier not corroded and then maybe check the transmission switch which tells the bike what gear its in to prvent the awd not to work unless the override is pushed. these 2 things work together to make it work correctly.
Polaris5
Aug 29, 2015 09:11 PM
house1
Aug 9, 2015 10:49 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Scottma518
Jul 10, 2015 12:42 AM
