400ex wont start cold weather
Old Dec 10, 2008 | 10:11 PM
honda400exracer3's Avatar
Default 400ex wont start cold weather
i have to wait to ride until it warms up then will start all i dose is turn over
Old Dec 10, 2008 | 10:17 PM
delphi26474's Avatar
have you cleaned the carb?. sounds like a fuel problem,
Old Dec 10, 2008 | 10:23 PM
yeah i do its clean so isent the air filter spark plug
Old Dec 10, 2008 | 10:56 PM
Stoopidbot's Avatar
Gotta love those cold blooded Hondas. It's electric start I'm assuming. Open the choke, pump the throttle about 8 times and then hit the button with throttle closed. Also, is it jetted properly? Have you ever changed the jets? What elevation are you at?
Old Dec 10, 2008 | 11:11 PM
jets are good it is jetted but right ocnce it starts will sit there and idle all day 1000 feet around there yes eletric start
Old Dec 10, 2008 | 11:42 PM
Rkangel777's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: honda400exracer3
jets are good it is jetted but right ocnce it starts will sit there and idle all day 1000 feet around there yes eletric start</end quote></div>
Mine's extremely cold blooded as well. I've heard that going up to a 40 or 42 pilot will help. I haven't tried it yet, but it is on my short list of things to do this winter.
Old Dec 11, 2008 | 09:04 AM
Stoopidbot's Avatar
Try the pumping the gas like I said before. That seems to work perfect on my 450.
Old Dec 11, 2008 | 07:43 PM
sprayedgt's Avatar
You should put in a 42 pilot jet. You just pump the throttle 3 or 4 times and it'll fire right up and idle no matter what the outside temp is. That was one of the first things I did to my '08.
Old Dec 11, 2008 | 08:21 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Cold air is more dense than warm, so it messes up your fuel:air mixutre, making you lean. Play with the fuel screw and that may do it, or you may have to fattern the pilot jet just a bit.
Also, it has a pumper carb, so if you pump the throtle a few times like has been suggested, that will prime it. I do that, and I never need the choke, not even in the coldest weather.
Make sure you run thinner oil in winter, like at least 10W30, or 5W30 if it is really cold. An ester synthetic like Maxima 530MX if you are willing to pay the tab......
Also see your owner's manual about running a hotter sparkplug in very cold weather.
Old Dec 21, 2008 | 10:37 PM
3racers's Avatar
Put on battery charger for 10 or 15 minutes choke pump start workes on mine after first time no more problems. Batt 1 year old.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Bm400ex
Jun 22, 2015 09:16 AM
sae156
1) Engine problems..
Jun 3, 2015 01:45 PM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
