Jetting on a 300ex
<div class="FTQUOTE"><begin quote>where is the jetting located and how do i check if its the right size? </end quote></div>
The jets are located inside of the float bowl. There is no way to check if it is the right size other than read the plug. This takes a ton of experiance to do it correctly. You can get it close if you have a plug chart. Many things determine the correct jet. Some are weather, mods, altitude, load and many many others.
<div class="FTQUOTE"><begin quote>I have a 1996 trx300ex and i have a problem with the jetting.. </end quote></div>
What "exactly" does that mean?
