Jetting on a 300ex
Old Dec 14, 2008 | 02:53 PM
adam27ktm's Avatar
Default Jetting on a 300ex
I have a 1996 trx300ex and i have a problem with the jetting..
where is the jetting located and how do i check if its the right size?
Old Dec 14, 2008 | 04:51 PM
Doctorturbo's Avatar
GOT BOOST!
<div class="FTQUOTE"><begin quote>where is the jetting located and how do i check if its the right size? </end quote></div>
The jets are located inside of the float bowl. There is no way to check if it is the right size other than read the plug. This takes a ton of experiance to do it correctly. You can get it close if you have a plug chart. Many things determine the correct jet. Some are weather, mods, altitude, load and many many others.
<div class="FTQUOTE"><begin quote>I have a 1996 trx300ex and i have a problem with the jetting.. </end quote></div>
What "exactly" does that mean?
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
