oil blowing out my exhaust.86 honda 200x
Old Dec 14, 2008 | 08:32 PM
caracer08's Avatar
Default oil blowing out my exhaust.86 honda 200x
other than possibly bad rings,could a bad head gasket,or anything else cause oil to blow badly out my exhaust?cyl.walls r good.
Old Dec 14, 2008 | 08:56 PM
cherokee99's Avatar
if its alot of oil i would say most likely cause is piston/rings. next i would say mabe the valve seals are GONE, alot of oil. are the 200x's 2strokes?
Old Dec 14, 2008 | 09:16 PM
caracer08's Avatar
4 stroke
Old Dec 14, 2008 | 09:22 PM
Doctorturbo's Avatar
GOT BOOST!
Unless you over filled the crankcase by about 3 qt's or have some sort of weird case vent problem it's going to be the rings. I don't see how it can run with that much blowby? What's the compression?
Old Dec 14, 2008 | 10:27 PM
caracer08's Avatar
not sure,dont have a comp.tester.but i just took a closer look at the walls and they r gouged.it needs more work than i know how to do.and more tools than what i've got.so,now i'll either scrap the motor,or find someone that will fix it 4 me pretty cheap.bein laid off sucks.
Old Dec 14, 2008 | 11:24 PM
GOT BOOST!
Sorry about your engine and your job.
My ATV runs great, but I may join you in the job deal. My boss is saying some weird stuff, so I will know in about 3 months when my contract is up.
Old Dec 15, 2008 | 07:34 PM
Duster_440's Avatar
if you've got everything pulled off and feel overwhelmed crate it all and take it to a respectable shop and ask them to "inspect" everything for you... this shouldn't cost more than 20 to 30$ at the most
if you jaw jack with some of the guys in service, tell them what's going on and your current situation they might look at it for free.
if you can feel the gouges then it is most likely time for a bore job.
depending on how bad the gouges are you may have to bore 2 or 3 thousands over...
new piston kit...
hopefully ur head and valves are good.
so yea you're looking at 250 to 300 in best case...
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
Steeldon
Sep 8, 2015 10:51 AM
DGNAZ
Sep 5, 2015 09:14 PM
bigred20653
Aug 31, 2015 12:41 PM
