four stroke tech 500cc warrior??
Old Feb 5, 2001 | 01:16 PM
pddan's Avatar
does anybody have one of these? or had any expierence with one? i am looking at buying one and was curious how dependable and rideable one would be?? they must do quite a bit of modifications does that make it tempermental?
any thoughts or comments??
Old Feb 6, 2001 | 11:54 AM
asfastasu's Avatar
The biggest thing you'll notice is the price! $2500 for the motor! Then to make use of the power, you'll have to upgrade the suspension. I have rode a 435cc Warrior. It ran well, but most of the power was at a high rpm. As far as reliabilty, that was in 96 and it's still running strong today with no major problems.
Old Feb 6, 2001 | 03:50 PM
kszach's Avatar
A friend of mine had his warrior built to 435 ???. Pretty sure 4-stroke Tech did it. I rode it a couple times, but didn't like it. It was a torque monster, but wouldn't rev much better than my lawnmower. I couldn't even pull wheelies very good, in fact I don't think it did pull wheelies. I don't think he runs it anymore. He tried steeper gears in order to get more speed out of it since he had so much lowend. Nothing solved the lack of top-end problem though.
Old Feb 6, 2001 | 04:09 PM
EasterEgg's Avatar
I had a 92 Warrior that I put a 435 kit in it from FST in 94 rode it 4 years without a problem. It did start smokin a little when cold in 98 when I sold it.
What pddan said is correct it was a torque monster but wouldn`t rev out. The 2 valve head is the limiting factor. I got the gearing so it wasn`t too bad for the trailriding I did, getting it to hook up was near impossible.
You would probably be happier with putting a higher comp. piston 10.25 to 1, WB trail cam with new springs & titanium retainers and port the head for about $500 vs $1000 for the 435 kit and put the other $500 into the suspension for a good all around improvement.
It was $1000 in 94 for FST to do mine. You send them your motor and they put in a larger crank, bore and sleeve the cylinder it also included a HD clutch. The price included all the parts & labor to disassemble, machine and assemble. On top of this you could go with a cam, port & polish and a bigger carb to help it breathe a little better but thats lots more money yet. HTH
98 Scrambler 500
00 Trailblazer 250
See my pic`s at http://www.picturetrail.com/riskracing
Old Feb 6, 2001 | 08:11 PM
4Tecate's Avatar
Save your money and buy a Raptor. By the time you spend that much money on FST you could sell the Warrior and add $2500 which is probably close to what the Raptor will cost.
Old Feb 7, 2001 | 11:42 AM
pddan's Avatar
while it is true the money spent on the motor and the warrior itself you could probably buy a raptor. but.... anybody with money can buy a turn key fast quad why not do something alittle different and also go in reverse?
Old Feb 7, 2001 | 08:14 PM
NewDSLover's Avatar
The Raptor has reverse, and is reliable so far. Why spend alot of Time, Money and etc. on a quad that you'll most likely have issues with. Now if it's a tinkering project that you want to see if you can do it. Then I would say, Have Fun!
Old Feb 7, 2001 | 08:39 PM
UltimateWarrior's Avatar
Hey EasterEgg I know it is alot more money but don't you think that not going with the port & polish head, cam, and bored carb that that could have been what was holding back the top end from revving out. I know that the two valve head hampers it also. Also one small advantage a stroked and bored Warrior would have over a Raptor is six speed verses a five speed. Though the handling is still not up to par.
exmotocrosser
Sep 13, 2019 06:12 AM
r1pilot83
Sep 27, 2015 07:38 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
