Help with a 95 Trail Blazer
Old Dec 19, 2008 | 07:09 PM
bigbearzfan's Avatar
Default Help with a 95 Trail Blazer
Heres the deal. I have a 95 trailblazer I am working on for as freind. It wont start. Found it had stuck rings so I replaced them, and thought for sure that was the problem. Doesn't seem to be getting fuel. I have taken the carb off several times and am very confident that it is clean. I have played with the pilot jet, turning it in and out, but I get nothing. Has spark and a new plug. It will fire if I shoot a little carb cleaner in it. Any thoughts??
Old Dec 19, 2008 | 07:27 PM
shaunsmaxx's Avatar
Have you checked your fuel tank and line?
Shaun
Old Dec 19, 2008 | 07:38 PM
Yes there is flow to the carb and there is fuel in the bowl
Old Dec 19, 2008 | 09:19 PM
eggenz7's Avatar
check compression. with stuck rings you could have an egged cylinder. optimum is 115-120psi. acceptable is 100psi. carb cleaner has a lower flashpoint so it will fire off with low compression
Old Dec 20, 2008 | 10:19 AM
The compression was over 100. The spark does seem to be a little weak. but even with weak spark the plug never appears to have and fuel on it at all
Old Dec 20, 2008 | 11:21 AM
drlang's Avatar
There is a possibility that the crank seals are bad and it is drawing air thru there instead of the carb.
Old Dec 20, 2008 | 11:30 AM
ftwflh's Avatar
Have you taken the PILOT jet out and cleaned it.The screw is just the air mix.Also do a compression check
Old Dec 20, 2008 | 11:33 AM
I had considered that. The machine had a complete rebuild, top and bottom end. The oil pump was bad so the shop that did the rebiuld told them to run a premix. It ran for about 4 tanks of gas then seized the rings. Would that also take out the seals??
Old Dec 20, 2008 | 11:34 AM
ftwflh's Avatar
Mix is 40:1 or you will toast a topend
Old Dec 20, 2008 | 11:35 AM
The entire carb had been cleaned, all the jets and passages have had cleaner and compressed air blown thru them
