XP 850 Noise
Old Dec 19, 2008 | 10:36 PM
TechRider's Avatar
Default XP 850 Noise
New XP EPS owner here. Any XP owners notice a noise when engaging high, low or reverse? It seems to be like play in the axle. Only happens when first engaging then no issue. Is this normal?
Old Dec 19, 2008 | 11:50 PM
dslanec's Avatar
Mine has made the same noise since day 1. I just assumed it was normal. Mine is the same way it only does it after i put in in gear and take off. Then it does not do it untill i switch gears again. I have 210 miles on it so far and no problems yet.
Old Dec 19, 2008 | 11:54 PM
Koerbs's Avatar
Its the same problem the old twins had, its normal and won't hurt the ATV.
Old Dec 20, 2008 | 08:40 AM
TechRider's Avatar
Thanks for the info. I was hoping that it was normal.
Old Dec 20, 2008 | 10:54 AM
HIGHOCTANE's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: dslanec
Mine has made the same noise since day 1. I just assumed it was normal. Mine is the same way it only does it after i put in in gear and take off. Then it does not do it untill i switch gears again. I have 210 miles on it so far and no problems yet.</end quote></div>
Exaclty. It only doesn't when you take off the first time after you change gears. I've noticed it is a little louder when cold,and a little louder in reverse on mine.
I don't think it is the same driveline lash issue the old sportys have. In anycase I do believe it is normal. To me the sound seems to come from the clutch/transmission area. I susect something with the clutch,but it only does it on the first engagement in a gear. And on mine it is a sharp "clack",not real loud,but sharp.... Mine has done it since day 1.
On my old sportman the noise seem to come from slop being taken from the entire driveline,prop shafts,diffs ect. it was more of a deep "clunk" and would do it all the time,especially going down hills if you were on and off the gas.
Ok,as usual I got carried away,lol.
Bottomline TechRider-Like everyone else said,Don't sweat it. Ride and enjoy.
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
firsttimerider
Sep 20, 2015 09:07 PM
