Polaris 1995 300 4x4
Old Dec 21, 2008 | 02:27 PM
johnpedro's Avatar
Default Polaris 1995 300 4x4
What is the proper way of changing the boots. I have the axles out at this time but I don't know what comes apart to get the boots on.
All information will be helpful.
Old Dec 21, 2008 | 03:10 PM
big_kid's Avatar
remove the big and small clamps. finish ripping the boot so it will come off. wipe grease away. thare is a clip on the axle shaft next to the CV joint. open this up with snap ring pliers and pull the CV joint away from the axle. its on splines.
install the new boot, small end first. fill boot with supplied grease. slide CV joint on shaft until clip catches joint. install big end of boot and tighten both clamps.
hope this helps....
Old Dec 21, 2008 | 03:39 PM
johnpedro's Avatar
How do you get the cv joint apart to get to the snap ring?
Old Dec 21, 2008 | 08:43 PM
big_kid's Avatar
clip should be right thare. ive also heard of guys taking a rubber mallet and giving it a couple of whacks and it will slide off....
Old Dec 21, 2008 | 09:10 PM
94harley's Avatar
Use a rubber mallet and just pound it off the axle, same way going on. The snap ring big_kid is talking about is on some Polaris axles but not the one your doing.
Old Dec 22, 2008 | 10:59 AM
big_kid's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 94harley
Use a rubber mallet and just pound it off the axle, same way going on. The snap ring big_kid is talking about is on some Polaris axles but not the one your doing.</end quote></div>
couldnt rember if his has the clip exposed or not. thanks.....
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
